21 - 29 of 29 Posts
wow.. your a ways away, im from tilbury area, near windsor.
Thats far south, is it? hows the weather LOL
Originally posted by oz450r@Sep 9 2004, 05:33 AM
my 12:1 has 3 rings as well
oz450r or Crowleyoffroad, either of you guys have a aftermaket cam? 1 or 2 stage and if so, was there any problems with the higher compression piston hitting anything? :mellow:
the higher compression pistons come with deeper cut valve pockets than the stock piston with the intent of accomodating higher lift cams. if the cam you pick says it will clear the stock piston, it will clear the high comp one by even more ...........mixxer
Thanks Mixxer! :D
Weather is fine, got a lil lite rain from the hurricane but nothin major
Discussion starter · #28 ·
So which one should i get without having to use racing fuel?
Originally posted by CrowleyOffroad@Sep 9 2004, 09:02 PM
I have a 13:1 JE piston and a 02 CRF cam.  Not overly impressed with the results.
Jon
Do you have it piped and if it is, maybe you need to port the head!! Hotcam told me I can get another 5% out of my engine if I port my head!! B)
21 - 29 of 29 Posts
