Just wondering what you guys use for towing & how you are towing if a quad breaks down in the dunes & there are no sxs or four wheelers available from camp & need to use another quad etc.last year my buddies battery died at night & I went to Pull him so he could bump start the engine(which he was able to do & get back without lights on since battery was toast) facing slightly downhill with a 20'x1" strap & it ended up destroying my rear grab bar & flag.i think what happened is after I got him started & I slowed down some of the slack came forward & got wrapped around my paddle/axle which pulled the grab bar down.i had attached my tow strap to the grab bar.anyways I don't want rookie mistake # 268 to happen again ! I was thinking of getting a smaller 12'x1" (shorter)strap & attaching it around my swingarm & to a low point on other quads frame so I'm not pulling the other quads front end down/dredging but I'm now concerned that strap will slide over on the (swing arm)& get wrapped up in sprocket or brake rotor if it's a long tow back to camp with a lot of turns/dune peaks etc.any ideas/experiences would be appreciated....
