Bad stator?? Or is something else wrong
6.3K views 2 replies 2 participants last post by  Mematt98
#1 ·
I have an 05 trx450r. Has a Yoshimura exhaust and stage 3 hot cams. It cuts out (sputters) at mid to full throttle. I adjusted the valves and changed spark plug (there was almost nothing left of the spark plug). It ran great (didn't cut out anymore) so I rode it for a little bit. I went to adjust the decompression valve and noticed the exhaust rocker arm roller was toast. It had about 1/4 inch of play in it. Yes I know, its terrible. I'm surprised it ran. Had a loud ticking tho. So I replaced it and adjusted the exhaust valves again. Now it has tons more low end power but cuts out at mid to full throttle. My question is how much can the stator be out of spec. I forget which wires it is but the one set of wires test 8.1 ohms of resistance. If i remember right its supposed to be between 9 and 25. Could that be the problem? Its not that far out of spec thats why I'm not sure how much that would make a difference. I just bought the quad to fix up so I'm not sure what size jets it has. Anyway, enough of my rambling. What do you think?
#2 ·
I had similar issues and it was a bad stator. Ran strong low to mid but would cut out also. When I tested the stator with help from a friend, it was putting out around 6 volts which was not enough to burn the rule. Pull your plug and if it is blacker than night you do not have the spark to burn it. You can find my thread which I just up dated.
