If you can get a good deal on it scoop it up. It will work as easily an a TRX FCR.
I have 2 crf fcr's on my 05's and they fit fine it's on the 06+fcr with the sensor in them that wont fit the crf fcr's fit just finethe crf carbs wont fit under your tank they are too tall.
the yfz carbs are perfect for the 04-05[/b]
The 39mm fc r won't give you anymore power htan the stock carb just better throttle response, buy the 39 and then get it bored thats when you will get the extra powerthe 39mm is not too small for the trx b/c the stock carb is a 42mm and the 06-08 is a 40mm i was thinkin of doin the same thing will it work fine as a 39mm?[/b]
