Just wandering if i will have to change my shims when i install the hrc cam in the 450r? If so what size? Any info will be appreciated thanks
Honda's shims are $6.80 a piece. Yamaha YZ450 shims, same size shim, is $6.62 and Suzuki shims, same size, is $8.51 each. They're expensive in a big way. Any time you change cams, 400EX or TRX450R or anything else, ALWAYS set the valves. More than likely, if they are within spec now before the change, they will be afterwards too.You can always get a shim pack from your dealer. I dont believe they will cost mroe than $5 for an assortment of them.[/b]
They had to change the shims on mine :huh: , it took them forever to get them in... The dealer told me what shims are but i seem to have forgotten, can someone breif me on them? even a picture or link would be nice...Originally posted by hondared450r@Jul 20 2004, 02:07 PM
http://www.hotcamsinc.com/catalog.asp toward the bottom of the page, use the slider bar.They had to change the shims on mine , it took them forever to get them in... The dealer told me what shims are but i seem to have forgotten, can someone breif me on them? even a picture or link would be nice...[/b]
top dead center...idk exactly what it means..i wish i knew some1 around me that could show me engines...u can really only learn so much off the intronetOriginally posted by Trx450Ryan@Jul 27 2004, 04:45 PM
Whats the TDC ???
