Why is oil coming out of this?
228 Views 12 Replies 2 Participants Last post by  Tyler’squad
Wheel Bicycle tire Tire Automotive tire Motor vehicle
so I just did a oil change and I’ve been riding for 30 minutes and now their is this white oil coming out of this hose that is like in the head anyone know why this is and if it’s bad?
thank you very much
1 - 13 of 13 Posts
Its your vent tube coming out of you valve cover, going by you saying head. White oil is usually indicative of water in the oil. Do you ride in a lot of water? Is your vent tube hanging down below motor? And how does the quad run?
No I was riding on the roads so it wouldn’t be water and yeah its behind the motor angling down and it runs good
Is that hose supposed to be their or not I’ve been looking what people are saying and it might be supposed to be transferred to the transmission
It’s supposed to be there , it’s a vent tube to alleviate pressure in the head. There’s 2 more, one coming out the case (oil side) next to clutch perch, and one coming out just under starter (tranny), all 3 relieve pressure from the motor. Most people run the little k&n filters on the ends and Run them to the air box.
but yours should at least be running to your air box against the filter. Having it hang back by the rear suspension will get a little debris or water sucked in it when flying thru mud water etc. I’ll send you pics in a few.
But alls you need to do is re route them. The head & case tubes usually go into a T connection then one tube to the airbox, the other tranny vent tube runs up to your heat shield under gas tank in a little slot, it gets turned downward when putting it in slot. Ill send pics shortly. But i would check your oil to see if it’s milky or white. Water bad.
My case and head tubes go into this T fitting then to my airbox. The tranny vent tube runs separately to the airbox. And to the little filter at bottom of box. You can put the filters on each tube and run them how you want.
Tire Wheel Bicycle tire Automotive tire Vehicle
Automotive tire Tire Automotive fuel system Car Motor vehicle
Motor vehicle Automotive tire Hood Automotive design Vehicle
Okay so yours is connected to the airbox I’ll do that thank you. It took so much oil you can’t even see it in the oil side window
If all your oil is coming out of the vent hose then you have other problems too.
How much oil are you loosing? Have you done any motor work to it? And how much oil do you put in it? Running the vent hose to your airbox isn’t going to stop the oil leaking, a little is normal, a lot is not.
And what year is your quad & what mods do you have.
Idk I might try putting it up to the air box putting more oil in it then see what happens. It’s a 2008 and I have a hmf and that’s about it
.73 quarts or 24oz roughly is how much you should be putting in, you don’t want to overfill these machines. You probably put too much oil in and that’s why it’s coming out of the vent tube. Another reason could be blow by from bad piston rings. If you put in the correct amount of oil and it’s still coming out of vent hose (a lot) then i would recommend a leak down test to see if there’s a bigger issue like bad rings, or valve seals etc.
hopefully it was just over filled. Let us know.
I think it was just high oil I put more in and rode it and it’s good
  • Like
Reactions: 1
1 - 13 of 13 Posts
