Web 493/729+2.5(5)DEGREE CAM
919 Views 7 Replies 4 Participants Last post by  556KingR
I have a brand new Web cam for sale. Its a custom cam that takes the 493/729 and adds a few more degree's of duration.
I know nothing about this cam other than what Im telling you. I know Web gets $285.00 for off the shelf cams so this one may have been more. I got it in a package deal and I have other cams I run.
Really no need for pictures, it looks like every other web cam!
$200.00 shipped
1 - 8 of 8 Posts
Bump for a good seller and great price.
Thanks Gar! I have a feeling this is a good power producer for a big bore....like a 480-500. Probably has a nasty midrange. You guys know how I feel about Web cams by now I and I dont run them so Ill never know what it will do. The standard 729 makes good power so I would bet this is even better. I always felt they are harsh on the valve train though.
Lets get this thing sold! Web Cams can produce some awesome power and you couldn't ask for a better seller.
Lets get this thing sold! Web Cams can produce some awesome power and you couldn't ask for a better seller.[/b]
Thanks bro ;) Id do $190.00 shipped tonight! Common, I need to finish my build here.....
Gary, can you please verify if that cam is the 493/729 or the 493/739?
Its the 729 version.
I did the specs working backwards:
We know int 110 lc and exh is 104 lc.
We know int is 252 dur at .050
and the exh is 252 dur at .050
So we have int opens @ 26 BTDC and int closes @ 46 ABDC
then the exh opens @ 40 BBDC and exh closes @ 32 ATDC
You have 58 degrees overlap
Just add 2.5 degrees to either int or exh, Im not sure which lobe has the +5 added duration.
Know you know the cam specs.
Bump for the King!
Thank you Mr.Zips!
Yes it is the 729 Chad.
1 - 8 of 8 Posts
