I can't remember does the Web 208 need to be degreed in and I know you should run stiffer springs when running it but does it have to have them running in an 06?
Thanks
Jake[/b]
That's were I'm at... I want the personality of the web and the mtce of the HC3... Having my cake and eating it too... I really don't put too many hours on my bike (50 or so/year) so I think I may jump on the web.I was really wanting to go to a WEB for my build but was worried about valve train wear and always having to shim..so here i am with a HC3[/b]
Think of it this way....if you dont have to sink the guides for the H3, why would you have to sink them for the Web? They have almost the same exact lift.... In fact the Web has a reduced base cicle so that puts the peak of the lobe (max lift) lower than the H3.
So if two cams have the same lift, what makes one have more power than the other?
couple things..... L.C.'s..... which can also vary things like overlap..... and ramp rates.
One of the reasons Web's sometimes make a little better power is to pop open the valves quickly and to shut them down quickly. Thus why we say they are "harsh" on the train. They have steep aggressive ramps....[/b]
Let me try and start a fact list for this cam using the FBC billet core - I know the old RBC needed degreed in, I'm not sure about the FBC. We need some clarifiction on some of these points. Maybe we can get Dan to chime in here, when he is back from the races. I like this cam and I intend to run it.
Shortened Valve guides - yes or no? I think either way its a good idea.
Stiffer springs - Yes
Bigger buckets - No
Needs degreeing in - Not sure, but leaning towards no (billet only)?[/b]
Bigger buckets - No
I'm not sure why there are thoughts that the 208 needs degree'n..... you don't have to degree the 208...
stiffer springs yes...
sink guides (04/05) yes....
bigger bucket not required but suggested...
