Web 208 Cam w/ Adjustable Cam Sprocket
969 Views 4 Replies 2 Participants Last post by  mccown450
I have a web 208/921 cam. This is an excellent mid to top end cam that makes tons of power. It is used alot in mx, drag, and tt bikes. I believe this is the rbc version, but dont be scared by all the valve train horror stories. If you stay on top of you maintenace and keep the valves shimmed properly you wont have a problem. This cam has the flange welded on and comes with an adjustable cam gear. Looking for $140 shipped or will trade for a new stage 3 hotcam. Will fit in all 04-07 bikes.
1 - 5 of 5 Posts
TTT
if i had the cash to upgrade my valvetrain i would trade you my stage 3
if i had the cash to upgrade my valvetrain i would trade you my stage 3[/b]
All it needs is heavy duty valve springs which you should have with the stage 3 anyway.
the stage 3 is basically a drop in cam. i'm sure the motor like the HD valve springs better, but i know alot of people run stock springs and are fine.
i'll see what i can do if you're interested. otherwise, free bump!
1 - 5 of 5 Posts
