venom 470
2588 Views 16 Replies 11 Participants Last post by  nicotrx450r
2006 pumpgas 470, stock valves,venom head, stockcarb,stock intake with K&N, HS2, and CHM pipe.
On our dyno anything over 50hp is joy to ride. very impressive. with intake, bored carbed, maybe little more cam this thing would be 55 to 56 no prob. good job venom.
yes im being serious. we have had our differences. hey we all have our ways of doing things and mixxer and I may never see eye to eye but i will allways give credit where its do. good running bike.
no hidden agenda either...
1 - 17 of 17 Posts
wow that is very nice with a stock intake and stock carb on pumpgas
would love to see this one with the things you mentioned
sorry guys its a CHM pipe not a DASA.
Cool, thanks for sharing, 50hp isn't slow,
what gearing are you runing??
i beleive he went to 15 tooth sprocket. ill check our notes on the dyno run,
thanks garret, very nice of you to post the info.....
seriously
john
Nice work John, and nice post Garret. Thanks for sharing!
was this with a bigger bore, or stroker?
thanks
How about a comparison run with your intake? Would just be a good comparison. Good power on a mild build.
Hey mixx, if you know who's this is, was it an all out head job or just a mild port?
we dont have the bike anymore. he had a budget on what he wanted to spennd for dyno time.. it was stroked not bored.
Nice run...good lookin curve and good numbers!
Shame, looks like a good bike to do a few tests on. Do you know which crank they used?
Hey mixx, if you know who's this is, was it an all out head job or just a mild port?[/b]
stock bore stroker with a stock valvetrain.....
i'm sure an intake would help a big part of the band...
When you guys built this did you use the HR +3 crank??? If not, how much would the crank work cost?
we dont have the bike anymore. he had a budget on what he wanted to spennd for dyno time.. it was stroked not bored.[/b]
I believe that was my bike on the dyno, and if it is my quad is bored not stroked.
Thanks again fuel Customs, you guys did a great job tuning my 450
It ran real strong at Pismo Beach.
I have stock gearing
The head was a full port job by Venom, with stock valves and springs
Venom 470 Big bore kit
Stock Carb and intake
CHM Full system exhaust and HC2
Oah and I figured out what my starting problem was. I checked my decompressor PSI and it was at 30. I bumped it up to 60psi and it starts every time. My fault considering I put the motor togeather. Thanks for the help fuel Customs you guys rock.
P.S. Hows the supercharged YFZ comming along?
1 - 17 of 17 Posts
