thats no good , that one lobe looked all messed up thats for sure
not really looking for a polished job i guess i can see it better here, i cant get a good pic of it, im goign to let soyo take care of it and he can post on here what he thinks!!that sucks for sure.. the portwork does not look abnormal to me ( looks like a couple humps going down but not as bad as others I have seen).. if you were looking for a polished finish then I can see your dissapointment for sure.. who ported the head ? You deffinately have cam issues.[/b]
yeah thats my fault i thought once you shimmed the valves they are set for good they have never been adjusted!! :_specialED:Way off clearances? It would seem to the untrained eye that you have a clearance way off and it dented the bucket.[/b]
just out of curiositiy ( i know spelled wrong ) how does preignition cause clearence issues ?Way off clearances? It would seem to the untrained eye that you have a clearance way off and it dented the bucket.[/b]
yea that cam was WAY to tight, you had a clearance possibly a alignment issue and with that boot ripped open
no wait i got it, that hole in your boot cause a very very lean condition cause it to burn hot, too hott
causing whats called pre-ignition causing the valves and cam to have clearance issues
pre-ignition will cause the piston to go back down before it is supposed to , so it will pull the cam chain down abruptly cause it to apply more pressure to the cam and valves making it tighterjust out of curiositiy ( i know spelled wrong ) how does preignition cause clearence issues ?Way off clearances? It would seem to the untrained eye that you have a clearance way off and it dented the bucket.[/b]
