1 - 2 of 2 Posts
Disassembled clutch case, clutch and other components to diagnose a starter clutch problem am wondering if the atv needs to be in neutral to enable the gears to free spine and if so do I need to reassemble clutch and push rod to get into neutral. Having trouble getting shifter to function properly since I removed the rod. Most likely dumb questions but trying to learn. Any help would be more appreciated 🙏
Discussion Starter #2
I've got it in neutral still conot spin by hand. Would this failure be a reduction gear or starter clutch? Or am I overlooking some things?
1 - 2 of 2 Posts
