TRX450r Billet cam tower that is setup for a .500" lift big camshaft. Has the bucket bores setup for 31mm buckets. No buckets included. It does have a helicoil for the valve cover bolt & works fine. Also has a little surface wear that is only cosmetic. It also includes a cam spacer to be able to run standard length cams & longer big cams
