1 - 5 of 5 Posts
On the Trx450er the weight for the decompression system is in the way so you can not use a cam sprocket holding tool. My Clymer manual says to use a flywheel holding tool but I remember reading about putting the quad in gear, holding the brake, and using an Allen key to hold the crankshaft so I can break the cam sprocket bolts loose. This sounds good to me but I don’t want to strip the crankshaft where the Allen key fits in to turn it over. You guys ever do it this way? Will the Allen key strip the crank?
take off the inspection cover for the crank on the left side of the motor and using a socket and ratchet hold it there. that allen key hole is for a cover for the crank. nothing more
The inspection cover for the crank is on the right hand side of the quad to the right of the clutch cover...It is a 10mm hex for the cover and there is a 8mm hex behind the cover on the primary drive gear mounting bolt used to turn the crankshaft over..... I remember hearing people hold the crankshaft in place by holding on it with a hex while they break the cam sprocket bolts loose. I want to know if the primary drive gear mounting bolt will strip or loosen up.
It torques way way higher than the cam sprocket so it should not loosen. I have done it this way many times. If you have a small impact or cordless impact you can probably zip them off with it without having to hold the motor.
Discussion Starter · #5 ·
Thanks Duke appreciate it. I knew somebody had to have experience doing it that way. Too big of hassle using the flywheel holder
1 - 5 of 5 Posts
