tokyo cdi, hmf, 44mm , bored crf fcr, CP piston
2135 Views 31 Replies 15 Participants Last post by  rrguy
$145 New CP piston I have a couple options If I can get it placed with my order (SOLD)
$35 100mm head gasket
$35 06 450r top end gasket + valve seals
$175 06 Tokyo cdi (SOLD)
$50 06 srp cdi (SOLD)
$145 06 NEW red carbon fiber Bill Ballance HMF slip on
$199 Full White Brothers Pro FLo exhaust 05 low hours
$199 New Big Guns Race ceramic coated 06
$155 Lectron bore 44mm with power jet/ aux jet (SOLD)
$89 Web Cam 943/921 Drop In
$75 04 crf cam / hrc 04 sold
$159 New Red IMS Tanks
$25 Denton graphic kit
$79 06 450er subframe
$69 05 pcd blue sub frame
$99 05 bent frame pcd blue
$325 +3 JRD arms 05 but ( 05 spindle available )
$425 LT Ohlins shocks 19" long
$55 Baldwin double row carrier sold
1 - 20 of 32 Posts
not really sure what you mean but id be interested or will buy it if it is a 94mm high comp cp piston 04/05 of course, pm me if you want
biggun
is the baldwin carrier still in good shape or needs the bearings? picture?
Its in good shape. The bearings are good, spin smooth, not loose. I have a new set NTN one of the top bearing manufactures just cause sometimes its nice to install new while its apart.
I can get a pic up sorry remembered I need to take one.
thanks
Greg
How old is the Lectron, what kind of shape, did Packard set it up, set up for gas or alky?
Thanks
just curious what is the tokyo cdi?
just curious what is the tokyo cdi?[/b]
It is a vortex cdi with some maps they found to work best, you can reprogram it & 2 different maps are selectable via a rocker switch on the handle bar. May be one to get a holeshot then switch back to track cdi, or one for drags & switch back to one for the dunes. You can have one for better top end & one for better all around power.
Hope that helps.
Hope that helps.
sent you pm.
Thanks[/b]
Not sure it was a older one bored to 44mm but I understand it was serviced.
cdi 55
top end gasket kit with valve seals, exhaust gasket $36 shipped
crf or hrcII cam $69
pm's replied to
thanks
Thanks
is the crf carb an actual crf carb? Or is it the stock 06 trx carb? Does it include hotstart cable?
how did you like that web cam?
how did you like that web cam?[/b]
I like it the most for stock bore & stroke. The plan is for a BB stroker, I think I can get by with a cam that is not so good all around & littler more top end? I hope so. lol
1 - 20 of 32 Posts
