Tire size help
2K views 3 replies 2 participants last post by  CJM
#1 ·
I'm just about due for new front tires. The front size is 21x7x10, rear size is 22x11x9. Does this seem like an odd setup? If so how would this affect the handling.
thank you
#2 ·
22" rears are usually used for alot of XC racing, they are too large for most anything else imho.
I run 22 fronts simply b/c they are off my old 400ex and 20" rears. Most people run a 21 or 22 front and 20" rear for most riding.
#3 ·
I'm thinking previous owner put the 22 in the rear for added ground clearance. up here in northern jersey all the trails are all very rocky. I'm more curious about the 21's in the front. should the front tires be smaller then the rear? I thought the fronts should be taller then the rear?
#4 ·
Well yes, usually fronts are larger. But since they put 22's on they arent.
