1 - 1 of 1 Posts
I have a 07 450ER and i had to replace my Starter gear. Somehow someway i think i messed up my timing. When i pulled off the starter gears i took off all my gears except the balancer gear. Now i lined up the 2 dots on my starter and balance gears when i reassembled. It just turns over like it has no gas. I have good spark. Took off head and made sure the cam gears are lined up. opened the inspection and its on the T. The lobes on cam are facing towards the back of the quad. The dot on the right side thru the inspection window isn't even in the window. Did i put on the starter gear wrong and then my balancer gear would be wrong as well?
1 - 1 of 1 Posts
