1 - 2 of 2 Posts
I have a Trx450er and my quad jumped timing so i went to fix the timing and now my makers wont match up. The t and the the one on the starter clutch dont match up. What can i do to fix this?
Super Moderator
Skip to the 4:52 mark in this video - it'll show you how to check your cam timing -
If your marks don't line up, remove or un-tension your cam chain tensioner and unbolt and remove the cam sprocket from the cam. Then move/rotate the cam sprocket in the cam chain a tooth or two, re-install the cam sprocket onto the cam, and check it again. Remember to re-install your cam chain tensioner each time you check the timing - a loose cam chain can slightly affect how the timing marks look and line up.
1 - 2 of 2 Posts
