The 06 is the exact same... Except there are 2 screws holding on the black cover on the right side of the carb.Pull the carb...
Im not sure what year of bike you have... but if its the 04-05
Take the screw out that is holding the black cover onto the side of the carb... you will see where the throttle cable attaches to the carb (it goes around a semi circle piece) Unhook it from the carb and then just screw it out of the carb...
Im sure the 06+ are similar...[/b]
