1 - 5 of 5 Posts
well i was looking to buy a hour meter to stay on top of my quad maintenance, i was intially gonna buy the DR.D hour meter. but then i cam across a hour/tach meters. one from moose racing the other from tiny tac.
the only reason i was intrested in the tach/hour meter combo is because i wanted to make sure my idle is set to honda spec, 1,700RPM. other then that i will never need the tach.
my quad is stock and i have never touched the jetting or idle, as is fr0m the factory.
i have a couple questions first,
- how accurate are these tachs?
- should i buy one?
- is idle that important to set, my e-start starts perfectly, and i dont wish on changing the idle anytime soon.
here is the moose racing tach:
http://mooseracing.com/catalog.jsp?level1=...amp;startPage=1
is says: "Firing patter: 1 spark = 1 rpm resolution in 10 rpm increments "
here is the tiny tach unit:
http://www.tinytach.com/tinytach/gasoline.php#
i have no idea which option to get this unit with? "this one Used on engines with one spark firing on each revolution of the crankshaft"?
YamaWho?
id imagine they're somewhat accurate. i wouldent think they're acutally accurate within 10 rpms but hey who knows?
but me... i set my idle by feel, sound... so is a tach necessary, not really.
Tiny Tach has done a good job for a few of my customers clocking new builds....
I use the Trail Tech Vapor...
just get the hour meter, the idle should go by ear... it shouldnt lug during idle, it should be smooth and at a semi quick pace. it should hold its own during startup basically, other then jetting issues.
get the hour meter and be done with it
1 - 5 of 5 Posts
