1 - 8 of 8 Posts
The Allen holes are stripped out..what to do..have to much slack on new chain...fudge!!
How in the world are they stripped? Those bolts only need 15 lb ft when torquing them. Either grab em with a vice-grips or cut a slot in them and use a straight slot to back them out. Get new bolts and torques them to the proper spec.
Discussion Starter #3
Bought it used..got new bolts on the way..thanx
If the heads of the bolts are stripped, I would make sure to check the threads in the swingarm. I’ve seen guys strip those out and I can only imagine that if the heads are stripped, the threads may be messed up a bit too.
I smashed an SAE allen socket in one that was damaged on mine then cranked it off.
  • Like
Reactions: hoser
Hammer and Chizle I have found the best way to get them loose if you can't get them out. Just hammer down each side of the bolt head and then put the chizle at a 45 Degree angle and hammer it in the loosening direction.
I made a slide hammer with a threaded bolt welded to 3/4" re-bar about 4ft long. I beat the piss out of it for days. Took about 4 good whacks with the slide hammer and out she came. I'm sure I loosened it up a little beating on it. To keep this from happening again, I drilled 3 SMALL holes along the length of the new pivot bolt and tapped the other end for a grease fitting. A squirt of grease every once in a while does the trick.
thats a great idea for the pivot bolt, and you can actually buy a pivot bolt that has a grease zerk in it, or a stainless bolt is a good option. But, the bolts that the OP mentioned are the four bolts at the rear of the swingarm that pinch the bearing carrier for chain adjustments.
1 - 8 of 8 Posts
