I’ve never adjusted mine before, but if you did adjust pre-load you would have less sag in the front end. You would also have less chassis roll in the corners, but I’d imagine it would ride somewhat stiffer. Yours already look as loose as they can go. Probably not a terrible lot of difference in changing pre-load with the stock shocks though.
If you really want a difference you could get yours re-valved. I’m not an expert on this, but I know theres other people on here that are. And there’s probably more threads on spring pre-load with in-depth and detailed explanations.
