I have a stock 2008 trx450r I've been having some carb issues with a steady hold in the throttle you can hear it sputtering and it die's the second you let off the throttle and it will not idle the only time it will idle is with the choke on I've taken it apart and cleaned the jets but its still having the same problems,i thought maybe somehow the jets could have a little dirt i missed clogging it up but i don't think that's the case, any suggestions on a fix ? Thanks in advance.
