I have the PEP rebuildable, here are some pictures of it on my 450R. Its a tight fit as you can see. I had to move the brake line down alittle for it to clear. Works great. I also have pics of before and after I put my nerfs bars on.
Just removed bolt holding brake lines and used zip ties to lower bracket. You can also see the tight clearance between the stablizer and the radiator.
If you don't move the brake line down the piston rod will rub this brake line.
This pic is before I mounted my nerf bars.
This pic is what I had to do to make the nerf bars fit. Just move the bracket up alittle. Everything else still clears fine.
