1 - 1 of 1 Posts
I have a question for you stator gurus:
I'm trying to diagnose a weak spark/no start situation. The resistance on the low side of the exiter coil (blue/white wires) is 7ohms which is right on spec. When I measure the high side (white/black+red), I get no readings. I then switched my multimeter to the continuity setting and registered nothing for the high side. Would this be a possibility that my stator is bad?
The stator was not installed in the quad for this test
1 - 1 of 1 Posts
