1 - 5 of 5 Posts
So i just put in a new starter clutch on my 2006 450er and now it wont crank over at all. It wont bump start either. Check timing. All lines up. New spark plug. Clean the jets. Dont know what else to check. The starter clutch went out then i was bump starting it for probably a day or two then installed the starter clutch and it wont start at all now. Can anyone help?
Sounds like a tight decompression setting, after a quick search it looks like multiple people have had this problem, if you fixed it already what did it end up being ?
Discussion Starter #3
Still havent figured it other than it being the one way bearing in the starter clutch again. Im having my friend try and redo the timing tom morning so im hoping its just off 180 degrees
1 - 5 of 5 Posts
