1 - 1 of 1 Posts
Hello. I recently tore my motor down to do a rebuild. Before I tore it down I ordered a new piston, and crankshaft/rod assembly. When i got it apart I found the crank and rod as well as the piston are in EXCELLENT shape. Since I already had a new crank I decided to put it in anyways. I would not hesitate at all to put this crank and rod in a motor at all. My engine builder said the same thing. The Piston is like brand new as well. It has around 4-5 hours on it. The reason I changed it is because I wanted to go back to a pump gas piston. It is a Sparks/CP 14.25:1 piston. If anyone is interested you can PM me with an offer and I can get some pictures for you. I will be willing to sell all the parts together or individually. The crank comes with the rod on it. The piston comes with rings, wrist pin, and clips. All of these are for a 2006 and up. Thanks!
1 - 1 of 1 Posts
