1 - 6 of 6 Posts
Pulled my plug today when I was going in to swap to a stg 2 cam, plug looks a bit lean for my taste. The photo makes the plug look quite white when its more a grey with a purple-ish hue to the ceramic. I was reading in Dyno room and seen that a 170+ main jet might suit better. Thoughts anyone?
06 trx450er
Hotcam stg 1 (soon to be stg 2)
Hmf full exhaust
Open airbox with Honda filter / outerwear
165 main
Ncvq 4th clip
42 pilot ( was only jet that allows me to start this thing when it's hot, pops on decel now. started at 48 n moved down )
Fuel screw 1.75ish turns out for highest idle
Float is adjusted correctly
Elevation 500ft Mohave desert
Household hardware Gas Nickel Wood Auto part
bit lean, but you need to cut away the metal and get to the ceramic to really see. called a plug chop
ideally you want it chocolate brown.
I'm planning on putting the plug back in... Don't have any extras laying around. Sounds like a bump in jetting is another need on the list. I'm thinking maybe 170 would be a safe bet since I'm swapping to a stage 2 and doing the green wire mod
how long you had the plug in there will affect it as well, longer more chance you get a better read
the cam and green wire mod will not affect the jetting
then id say your a bit lean there.
i highly suggest you go to a dyno. or be like me and get a welder to put a bung for an O2 sensor in there and have a buddy who has a gauge :)
1 - 6 of 6 Posts
