1 - 2 of 2 Posts
Hi I have a 05 450 and i was going down a back road with my friends and it started to bog then go back to normal for a few seconds then died completely and it was making a sound like a rubber belt for a utility quad was rubbing on the engine then i pulled in the clutch and it stopped when i came to a stop (keep in mind i was in fifth gear) and it wouldnt shift down or up put some how it went into neutral. the kick start wont go down at all. I have a stage 2 cam, 10:1 piston, aftermarket carb and i was running 110 octane in it. Can someone explain what happened or what i need to replace.
Your crank is likely locked up and the motor will need a complete rebuild with new crank/rod, bearings, etc.
BTW, your wasting money and actually making less horsepower by running 110 octane instead of 91.
1 - 2 of 2 Posts
