I need the bearing number that needs pressed into the left case, can anyone please help? I cant seem to find it
ooops sorry, shift drum bearing, its the one on the left case, NOT the right..... thanksShift shaft or the drum???
I dont see a shift shaft bearing only a seal.[/b]
here 91008-MEY-671 its pictured with the drum in the fischeooops sorry, shift drum bearing, its the one on the left case, NOT the right..... thanksShift shaft or the drum???
He's got it apart i just cant find a left side bearing for the drum in fische or the manual.Do you have it apart? If so, there should be a # on the bearing that honda can cross reference! Its the big i.d. yellow bearing right?[/b]
:11doh:its apart and i no longer have the bearing, it has been discarded[/b]
