Cliff Notes:
Bike had some clutch problems
Sat on its side for a few months
Gas was shut off to carb, then ran for dry afterwards
Gas was 50/50 premium/sunoco (not sure on octane)
Anyways, clutch is back together, fresh fluids all around, but I cant get this thing to fire at all
Will crank and crank all day long, just wont fire, even off starting fluid. Plug is brand new
I took the needle out, cleaned, pilot, cleaned, main, cleaned, starter jet, cleaned
My question is, Im assuming this is a float issue, how do I remove it to clean it?
This isnt my bike, I run FCR's on mine however and when the carbs are off the bike and you hit the throttle you can shoot dual streams of fuel across the shop... this FCR wont shoot a stream.... whats clogged/dirty? Im assuming that it SHOULD shoot a stream???
Also, along those same lines... The plug, after trying and trying to start, is dry
Thanks
Thanks
