Running 13.5:1 490cc Big Bore on 94 Octane – Safe or Not?
1 reading
109 views 2 replies 3 participants last post by  hoser
#1 ·
Hey guys, I’ve got a 2006 TRX450ER that I’m rebuilding and modding. Here’s my setup so far:
  • Athena 100mm 490cc big bore kit with CP 13.5:1 piston
  • Stage 2 cams
  • HMF exhaust
  • K&N intake
  • Re-jetted carb
  • Kibblewhite intake/exhaust valves
  • Fresh OEM crank bearings, cam chain, guides, seals, gaskets
  • NGK Iridium plug
I ride mostly trails and don’t push wide open a lot, but I do want to open it up once in a while. I have access to 94 octane pump gas.
Question: Is 94 pump gas safe enough for this build if I’m not pushing it hard all the time? Or should I be mixing in race gas to be safe? Also, do octane boosters actually make a difference at this compression ratio?
Appreciate any input from people who’ve run similar setups.
#2 ·
100 octane or better all the time or get a lower compression piston. az quad sells 12:1 pistons for that size bore i recall. could use octane booster like vp madditive or boostane but i wouldnt chance it
why risk blowing it up after spending so much coin?
  • Like
Reactions: h0nda450mainiac
