1 - 13 of 13 Posts
well i messed up the carrier while trying to remove bearings, whats the trick to removing the bearings? and any suggestions where to buy new axle carrier for stock swing arm ( 06 450r)
dont beat up the carrier is about all the help i can offer lol
i agree it does suck
but this give you the chance to replace it with a better aftermarket dual roll bearing carrier check with woodward specialties for a great price on one with bearings and seals
BUT if you want to go back stock then check eGay
heres a trick for you guys. Get yourself a toaster oven. Heat up the carrier at 400 degrees. and the bearings fall out with a few taps on a piece of plywood. The aluminum expands more than the steel. I also heat the aluminum and put the new bearings in. They slide right in and when the carrier cools down, they are tight. Then i install the new seals. Works for me.
heres a trick for you guys. Get yourself a toaster oven. Heat up the carrier at 400 degrees. and the bearings fall out with a few taps on a piece of plywood. The aluminum expands more than the steel. I also heat the aluminum and put the new bearings in. They slide right in and when the carrier cools down, they are tight. Then i install the new seals. Works for me.[/b]
OHHH very clever
You can either use a little propane torch or put them in the oven. I wouldn't go all the way to 400 degrees though. You need to be very careful using an oven because the grease inside the bearings will boil. When using an oven I always preheat to 150, then stick it in for 15 minutes then pull it out and tap it on the bench. This last time I just used a small propane torch and they fell out with a few taps.
I picked up my burgard billet carrier on ebay for $135shipped.
The heat/ cool trick works on alot of different bearings.. I did this with my crank bearing and case bearings, heat one cool the other in the freezer, if you do it right you dont even needa hammer
throwing it in the oven works REALLY well. i just pulled my carrier bearings last night and couldn't believe how easy it was to remove them. i had never heard of this before......thanks for the tip.
I need to replace my rear axle bearings and ive never done it before. the how to guide thats sticked doesnt show pics anymore. can anyone point me to the kit they got for a 2005 rear end? They have never been replaced before.
the same thing happened to me but i got new red stuff.
I do that to replace cylinder sleeves in my sled.
1 - 13 of 13 Posts
