refinishing a dasa
965 Views 9 Replies 5 Participants Last post by  blackdrag450r
hey guys my dasa has the paint coming off and the sticker is burnt so i want to know what you all suggest for redoing it and making it clean looking and hopefully won't burn off?
1 - 10 of 10 Posts
send it to me and i can take care of it for you....
how much you want to pay and what color??? haha
Next time you want to replace the packing before you burn the paint and sticker.
i bought it used and it was this way when i got it but i have been working on cleaning things up and this is one of them things.
the reason it burnt up i because it needed repacking, so just get it re-pc'd and get a new sticker from dasa and keep check on the packing that should keep it on there, you could always just polish the can tho
Anyone got a tip on pulling it apart man this thing wont budge?
Anyone got a tip on pulling it apart man this thing wont budge?[/b]
They are a pain in the @ss to get apart. I sprayed a lot of penetrating lubricant on both ends and left it over night. The caps came off pretty easy the next morning.
Pain in the A** aint even close i am ticked off right now but I have sprayed them down a couple hours ago we will see what happens....
well guys i still need some help ..... sprayed with penetrating oil......let set for almost 6 hrs and i still can't get it .......... anyother suggestions......
what i did is i carefully, and i mean carefully took the biggest flathead screwdriver i had and got it in between the end cap and the can, i twisted the screwdriver carefully or it will slip and make gouges, but i did that all the way around until it was out enough where i could take the hard rubber hammer and hit it in a downward motion while rotating....
once the one end cap is off, take the packing out and the core...
you will be left with an empty can and a end cap...
find something heavy that fits in the pipe and drop it in, shake it up and down so the object hits the end cap knocking it out...
i used an old capacitor from a car stereo system...
hopew this helps, i've had a few beers.... haha
1 - 10 of 10 Posts
