It seems that honda doesn’t offer the spacer between the rear sprocket hub and carrier bearing. Does anyone have the dimension to the OEM one, or know who makes one.
It sits here on the inner hub.
This is the issue without it no clearance between hub and carrier.
I had to cut the rear axle to get this thing apart. The guy before me had just replaced the carrier… one of those deals it was bad every things was seized. The carrier welded itself to the axle pretty much. Here a pic. Didn't realize that spacer was on the other side. I would have cut the sprocket hub if I had known. It’s all scraped now and long gone!
I am a machinist by trade so if I can find one or at least have the width of oem one and a couple other dimensions I can make one up!
