06 HRC cam new piston rings crank shaft cam chain sparks full exhaust uni filter many more bolt ons!
So i ran my two carb vent lines to my airbox. Nothing special, no filters or anything. Just in my air box against faom filter. My overflow runs down to bottom of motor. Ive been reading a few other posts about Atmospheric pressure not good for carb vent lines?? Whatever that means. I assume it means with all the turbulence in the airbox sucking in air during throttle can affect the way carb vents? Anyone hip to this?
I believe when these vent lines run down to bottom of quad, they suck up dust dirt water etc. and is the reason for carb gunk build up. So i ran my hoses to the air box against my faom filter. You guys think it’s worth it. Or will Atmospheric pressure cause problems with carb venting?
