it says use pro honda hp trans oil for the trx450r trans and im just mkaing sure its this stuff http://powersports.honda.com/the_goods/par...W&TheGoodsDir=0
Properties?... :huh:Originally posted by TRX450rlude@Jul 13 2004, 10:55 PM
thats the stuff I use....You will see some people using motor oi in both sides. thats not bad, but here is the issue... Transmission oil has different properties than motor oil ...thats part of the reason why Honda designed it this way...to keep clutch particles out of your piston, and to allow you to use tranny oil in the crankcase. Now why would someone use motor oil in their tranny I have no idea. It wont hurt it, but motor oil does not have the same properties that the tranny oil has...thats why there is tranny oil to begin with....so im not going to argue with anyone about this, but just use common since...there is tranny oil for a reason....it is way better on your clutch and tranny then motor oil. Plus you clutch wont want to slip as bad with tranny oil as it would with motor oil...becasue of the different properties.....think about it.
they are the two that make the color red....Originally posted by Outlwd+Jul 14 2004, 11:25 PM--><!--QuoteBegin-TRX450rludeProperties?... :huh:@Jul 13 2004, 10:55 PM
Do you mean like Boardwalk and Parkplace:lol: j/k [/b]
:huh:Originally posted by Rico'450R@Jul 16 2004, 02:19 PM
I used the same oil for my tranny that I do for my engine. Vavaline 10-40 for ATV use!![]()
well its none of my business what you use, My problem with that is not that you use it for the tranny, its that you use Valvoline....I personally dont like valvoline.... but thats just my opinion....I know around here its about the cheapest name brand oil you can buy.....Do they make oil stricly for ATV use?......cause you shouldnt be using auto oil in your atv...specially on the tranny side....Originally posted by Rico'450R@Jul 16 2004, 06:38 PM
What's up Lude. You think that's kinda of wierd. The manual says you can use the same oil!![]()
what proof do u have of this?Originally posted by TRX450rlude+Jul 16 2004, 05:45 PM--><!--QuoteBegin-Rico'450Rwell its none of my business what you use, My problem with that is not that you use it for the tranny, its that you use Valvoline....I personally dont like valvoline.... but thats just my opinion....I know around here its about the cheapest name brand oil you can buy.....Do they make oil stricly for ATV use?......cause you shouldnt be using auto oil in your atv...specially on the tranny side.... [/b]@Jul 16 2004, 06:38 PM
I said it was just my opinion, no proof. Actually after I posted that I did a google search on that oil and I did not realize Valvoline actually made a oil just for ATV's. It looks like the put quite a bit of R&D in it too. ...I kind of judge things by what they cost because im a electronics person, and in electronics you get what you pay for...If you pay more for it, 9 times out of 10 its better then the cheaper ones. Valvoline is just a cheaper oil around here, and I was just raised with everyone telling me that valvoline sucks....thats the only reason. I have no documented proof that Vavoline is bad.....I do know there are way worse out there. But I like to use the best I can, and Vavoline is simply not it. Im judging this on thier car oil....I have never heard anything good, or bad about thier atv oil.Originally posted by Jumbo747+Jul 16 2004, 07:23 PM-->Originally posted by [email protected] 16 2004, 05:45 PM
<!--QuoteBegin-Rico'450Rwhat proof do u have of this? [/b]@Jul 16 2004, 06:38 PM
the only reason your not supposed to use car oil is because it will make the clutch slip....but in your case there is no clutch. The only other thing I would be concerned about is atv oil is a high performance oil for high RPM engines....the oil dont break down as easy. .....I dont think it would ever cause you a problem though. as long as you change your oil often.Originally posted by Jumbo747@Jul 16 2004, 08:38 PM
i use car oil in my engine side but not the tranny side
