For anyone interested, I found out from Mark Baldwin how to properly wire a kill switch to the 450R. Follow instructions listed below:
1) Trace the wires form the stop switch (mounted on handle bars) to the white connector mounted to the left hand side of frame.
Note: The wires from the stop switch splits off (2) directions, (1) set to the head light assembly, and the other to the (white plastic connector).
2) Look for the black wire with the white tracer.
3) Splice, connect, or solder (1) wire from the kill switch to the black wire (w/ the white tracer) on the stop switch side of the connector.
4) Then ground the other wire from the kill switch to the frame.
That's all, your finished.
Hope this helps, any questions just send a reply to this post.
Tim
