1 - 6 of 6 Posts
2006 Honda TRX450ER
Hey guys, so I’m in the process of replacing the rear carrier bearings and before I pulled the bearings I noticed there was some play in the distance collar/spacer tube between the bearings in the carrier. Should that spacer have any play? I don’t know why/how something like that would “wear out” but if I need to replace it better to pick up a new one before installing the new bearings. Thanks!
Once the axle is installed it brings the tube in line with the bearings. Then when the axle nut is torqued it snugs the bearing up against the spacer tube.
1 - 6 of 6 Posts
