what kind of money are you looking to spend thats always a question before you decide what your going to build
Got your pm thanks and thanks for the good infopm'ed you[/b]
???? break down the cw cylinder web site or something got a ds 2 months ago so my head still stuck in that ds world :_idiot:If you need a crank i would get a +3 crank, if your cylinder is good keep it a stock bore with a high comp piston or if it's bad get a cw cylinder. Then a cam stage 3 maybe. Have your head ported with some good valve springs and i would get +1 ex, if your bike is a 06 or newer get the carb bored if not look for a used fcr and install a fuel coustoms intake and if it's a 04/05 get a dyna igniton if it's a 06 or newer clip the green wire, that would get you started[/b]
ya ive kicked that around on the nmotion they r down the road from were i work got on there site today lookin for prices ?? guess ill drop by get some quotes thankIf the cylinder is in good shape i would go balnced stroker crank. you can then l,ater afford a new cylinder and piston to break into the 500cc's.
Get an nmotion cylinder when you do so you can go as big as you please. actually 556 king has a pair for sail now might be able to get away with a bigbore stroker if you catch one for your price range.[/b]
