04 TRX450r
13.5:1 JE modified/lightened Piston
Razor thin head Gasket
Shaved "test" head ported and dimpled intake valve guides cut
exhaust cleaned and polished verified 17.1:1 comp
Dual Spring KibbleWhite Kit w/titanium retainers
HotCam Stage 2
182 main 2 turns out a/f
-4 Trailtech Flywheel
BigGun CDI
AMR Monster Coil
K&N + Outerwear
custom made poly/rubber intake (still testing at 3"x6.5")
15 front sprocket
Extended Axel
Razr II tires
Vapor Tech Computer
Full HMF Carbon Fiber Ballance with heat wrap
Entire carb interior smoothed and polished to a mirror shine,
Modified Butterfly valve, taper, and all moving parts !
Still not fast enough...
