1 - 3 of 3 Posts
I got a 2014 trx450r with oil in the airbox Anyone have any solutions? Has a new piston and rings with stock cylinder. Heard the rings aren’t sealing but not sure if the cylinder would be bad or if something is clogged up. Any help would be appreciated.
2004 TRX450R
Do you have the crank case breather tube hooked up to the right spot.? A lot of people including myself, have mistakenly connected this hose in the wrong place and oil can be pushed out into the air box. How are you trying to seat the rings?
1 - 3 of 3 Posts
