1 - 9 of 9 Posts
I’ve noticed I’ve been hearing noises kinda like the chain hitting or like a clanking noise. It’s coming from the front sprocket area. I can hear it and my buddy next to me riding can hear it, only does it when I’m hitting bumps, or if I’m going to slow for that gear and I hit the gas and turn left. I thought maybe it was my shaft to the front sprocket but idk. Any ideas what it could be?
Probably your chain hitting your swingarm because it wore through the front chain slider. Take a look and see. If it has been hitting it for awhile you may need to replace your swingarm. Otherwise replace the slider and you should be good to go.
chain is to loose or smacking your swingarm or skid
Discussion Starter · #4 ·
I was kinda thinking that to but my buddy rode behind me and said the chain isn’t hitting anything. The chains tight
Remove the chain, spin front sprocket. Noise still there? Is the sprocket loose?
I was hearing a noise perhaps similar to yours. Thought chain, sprocket even maybe transmission issues. Turns out the skid plate was loose and rattling. I have a metal skid plate too
Discussion Starter · #7 ·
I’ll look at it and take the chain off when I get back to it. I don’t have a skid plate so it’s not that. Thank you
Good luck
First, your chain should not be “tight”, that will cause stuff to wear much faster and can ruin a lot of different bearings. You want 1 1/2” or so of up and down slack.
Even if your chain is adjusted properly it can still smack the very front of the swingarm where it pivots and cause noise.
1 - 9 of 9 Posts
