1 - 7 of 7 Posts
That is your coolant drip. If it dripping, it means you need to rebuild the water pump (new mechanical seal and oil seal at least, possibly a new shaft, etc.)
Are you sure it is not oily coolant? Oily Gas would be very odd from there and would likely indicate other additional issues that would need to be investigated farther.
Discussion Starter · #3 · (Edited)
It may be oily coolant it was either that or oily gas I couldn’t tell and where would be a good place to get a rebuilt kit?
If you have some mechanic skills it is something you should be able to accomplish I’ve done it a few times it’ll take at most probably 45 minutes of work with the help of a good YouTube video.
1 - 7 of 7 Posts
