1 - 4 of 4 Posts
Ok, got my new '05 trx450r (all black) today and started the hrc kit install. I only have one ques., on the needle jet when you say 3rd or 4th clip setting from which end are you counting from? the end where the notches start or the tapered end? Should I adjust the air screw w/ all the hrc kit? Thanx in advance.
Actually I believe there are only 5 positions. So 3 from the top is 3 from the bottom :D But it is starting from the top so the 4th would be 4 down from the top position.
Dave
1 - 4 of 4 Posts
