1 - 10 of 10 Posts
there is a new mx track locally that its pretty close to me; so i`ve been practicing more frequently lately.
i`ve been riding for the past 8 years, mostly baja-style, so jumping is not my strongest point when riding an ATV
lately i`ve been starting to clear some medium length table-tops (40-45ft?), however; when being mid-air and in need to make some pitch correction, , i dont know how to properly tilt the quad forward or backwards.
dirt bikes do this by hitting the throttle or the front brake i believe....but the most i am able to do is to balance it a little bit by leaning my body .
am i just lacking the technique, or mid-air correction is different for atv`s?
I'm curious as well, I'm really not a flying device, but sometimes got to do it to be fast, but jumps are scary to me due to my inability to correct mid-air pitch.
I find it easier to use a higher gear low midrange RPM to gas up the front, rear weight bias also helps a bunch.
Still the small steep jumps seem to throw me out of control
pull in the clutch and hit the rear brake to bring the front down. It should be the same as a dirt bike.
WFO to bring the front end up.
Play around with it. Focus on one technique at a time until you have it down.
most people are stiff on the bike , moving in every way the bike goes so everytime they jump and the takeoff isnt perfectly smooth , combined with letting off the gas at the bottom and a blip right off the lip , they are all over the place once in the air.
stay smooth , relaxed
steady throttle
body position
dont try anything you feel not safe doing.
steady throttle
body position
As a life-long mx bike racer, just now dabbling in quads, I can vouch for the advice above. It's exactly what worked for me. Just took a little time to get comfortable and confident. Once I had that, being a little sideways didn't bother me, because I could correct or else know that I'd be fine on the landing.
Don't go Full throttle I rolled my trx 4 days ago, Swollen leg, and cut eye lid... Take it easy and learn a technique
Well, after the rest of the 2014 season, Steeve was right on the money, I even started to enjoy some jumps...
1 - 10 of 10 Posts
