1 - 7 of 7 Posts
anyone with the HRC kit running the LRD stage one kit, or just the pipe? what jetting are you using? thanks
I have the HRC kit and the LRD Full system. I talked to LRD at the end of July at DUNEFEST in Oregon. They suggested a 50 pilot, 195 main, clip on the needle in the 4th notch and 2 turns out on the fuel/mix screw. I also have a K&N filter. Hope this helps...
sounds like they are right for all except the 195 main....It will run fine with the 195 main, but Im willing to bet it would run even better with a smaller main.
Discussion Starter · #5 ·
right now i'm running hrc kit, full lrd, K&N with a 185main, stock pilot, 50 pilot is on order
<div align="right">index.php?act=findpost&pid=56609
[/quote]
I have since changed to the sam e jetting. The clip on the needle is on the 3rd notch. Runs way better now...
1 - 7 of 7 Posts
