lrd exhaust/ k&N filter how do i jet the carb?
1413 Views 3 Replies 4 Participants Last post by  scrapper450r
ok i have a trx450r 05 i bought a K&N filter for it how do i re jet the carb with the stock needles???
1 - 4 of 4 Posts
ok i have a trx450r 05 i bought a K&N filter for it how do i re jet the carb with the stock needles???[/b]
if you call LRD they will tell you how to set it up,they have no problem answering questions.
did you buy the lrd new? it should of came with some jetting specs, check the box.
some might chime in with similar mods
i had an lrd slip on. same year. if you got the jet specs from lrd, they are real close to spot on.
if not.......... you are gonna need around a 170 main. mine was a 168. pilot was good. the needle move was moving the clip down a couple spots at least. NO LID!!!!
it does'nt say that anywhere on the jetting sheet. i fooled and fooled with my needle. would'nt run right.
took the lid off. bam.
nice pipe. one of the nicest looking. the sticker falls off easily though.
if you dont have the jetting spec sheet..... call them. i always got an answer.
1 - 4 of 4 Posts
