So I have a 05 trx450r that will start and run when cold for about 5-10 minutes then die from a non fuel related issues and it will start back right after it shuts off but eventually gets to the point where it only runs 15 seconds, we have replaced the Cdi box with a oem the voltage regulator with a oem, I would like to add it normally runs perfect and revs great but now with it like this it won’t rev right and cuts in and out at about 1/3 throttle won’t rev past that unless it’s cold, so that’s why I’m thinking it’s something to do with timing is there anything that can pull ignition timing on it ?
