bought a 04 450r kicker while changing oil noticed case was stripped so i helicoiled it works great but the little peice that you screw the coil in with
that has to be broken off stayed in motor tried running 2 quarts through it with plug off no chance magnetized a very small phillips screw driver and put it in there no help nether any ideas thanks does the filter pick that up or is it going to destroy my bearings someone on the forum gave me a good answer it was take off the left case cover and flush it out tried tilting it to right side wth cover off filled with oil and leaned back to the left no luck also tried using one of those magnetic pens didnt work either any ideas.?
